opa82 kirjoitti:Olipas nätti toi RGV. Oisko teknisiä tietoja tollasesta?
www.suzukicycles.org kirjoitti:The RGV250SP uses a dry clutch and special 32mm carburetors with sensors for the airbox pressure. The bike also has electric start and uses ram-air technology (check the pipe next to the headlight going straight into the frame). The bike is supposed to produce nearly 70 hp when de-restricted (the power output is restricted to 40 hp in Japan, in Italy the power output is given to 67 hp).
RGV 250 Gamma SP 1997
Overall Length: 1 965mm (77.4 in)
Overall Width: 695 mm (27.4 in)
Overall Height: 1 095 mm (43.1 in)
Seat Height: 765 mm (30.1 in)
Wheelbase: 1 330 mm (52.4 in)
Dry Weight: 134 kg (295 lbs)
Engine type: Water-cooled 249 cc water-cooled 2-stroke V-twin. 67 hp.
Täältä siis.
Tuossa tarkempaa tietoa juuri kyseisestä vehkeestä: http://www.rgv250.co.uk/vj23info.htm
"Install the optional water temperature sensor to the optional water pipe and connect the sensor
and the optional meter unit with the optional harness." ZX-6RR Kit Manual
