onko kukaan törmännyt suomessa vastaaviin http://www.youtube.com/watch?v=NvGD_4Jf ... re=related
Eli 250cc hornetti kyseessä
General information
Model: Honda Hornet 250
Year: 2002
Category: Naked bike
Rating: 66.3 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 249.00 ccm (15.19 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 40.00 HP (29.2 kW)) @ 14000 RPM
Torque: 24.00 Nm (2.4 kgf-m or 17.7 ft.lbs) @ 11000 RPM
Compression: 11.5:1
Bore x stroke: 48.5 x 33.8 mm (1.9 x 1.3 inches)
Fuel system: Carburettor
Valves per cylinder: 4
Fuel control: DOHC
Cooling system: Liquid
Gearbox: 6-speed
More details Consult a Honda repair manual.
Physical measures
Dry weight: 151.0 kg (332.9 pounds)
Seat height: 760 mm (29.9 inches) If adjustable, lowest setting.
Overall height: 1,055 mm (41.5 inches)
Overall length: 2,045 mm (80.5 inches)
Overall width: 740 mm (29.1 inches)
Ground clearance: 170 mm (6.7 inches)
Wheelbase: 1,415 mm (55.7 inches)
Chassis and dimensions
Front tyre dimensions: 130/70-ZR16 61W
Rear tyre dimensions: 180/55-ZR17 73W
Front brakes: Single disc
Rear brakes: Single disc
Speed and acceleration
Power/weight ratio: 0.2649 HP/kg
Other specifications
Fuel capacity: 16.00 litres (4.23 gallons)
General information
Year: 2002
Stroke: 4
Compression: 11.5:1
Fuel control: DOHC
Gearbox: 6-speed
Physical measures
